By Kahuna - 9 Years Ago
The fuel line on my 56 Ford was cut and bent to accommodate a different carburetor. I'd like to know if anyone has a picture of a stock fuel line going from Fuel Pump to Carburetor. This is using the Stock Teapot 4 bbl carb. Just a shot of the side of the carb would help with the line installed. Thanks so much Jim
By Ted - 9 Years Ago
See if this picture helps. The car is long gone but this picture of the carb and its related linkage is still here.
Found another picture but a different car. This one has the air cleaner on it but the fuel line routing is still evident.
By oldcarmark - 9 Years Ago
Tee-Bird.com sells the correct 3 piece line Set from double action Pump to Carb . $25.00.
Thanks Ted & Mark Jim
By Bobwanna - 9 Years Ago
Kanuna, I snapped a couple more pix but am learning how to add them to posts? If this does not work I can email to you - Bob
Here are 2 more - Bob
Bob Thanks so much Again to Ted & Mark All those pics are very helpful Jim
Also, anyone know where I might find one of those fittings that connect the vacuum to the back of the carb? Thankyou Jim
I found most everything I need At Teebird products. Thanks for all the help Jim
