By stuey - 9 Years Ago
Morning Folks I've just purchased a new Ford 9" and would welcome comments/ suggestions on installation in a 56 f100. (street use, no drag racing) My existing setup seems to be motor/ gearbox = 4* down, driveshaft = 1.5* down, pinion = 5* up. What bugs me is how much leaf spring wrap up can I expect? I've seen as much as 6* quoted but this may be at the drag strip not street. I am thinking to aim for motor/gearbox = 3* down, driveshaft = see how it falls, pinion = 1* up. Assuming the driveshaft falls at the 1.5* figure I don't think I would be over working the UJs and there would be 2* pinion climb to come // with the gearbox O/P shaft. What do you think? Thanks stuey
Thanks for the reply. The starting point has to be parallel transmission / pinion. Depending on how the driveshaft lines up I think I will drop the pinion 1- 2 degrees There's also the added complication of the pinion being offset 1" to the passenger side. Thanks again stuey
