By Kahuna - 9 Years Ago
On the driver's side of the engine is a sort of road draft tube with a cannister on top. I think there's a filter in there that I should change. There is a bolt on top of the cannister, but upon removing the bolt, the cannister doesn't seem to want to release. Is there something else that may be holding it on? Thanks Jim
By carl - 9 Years Ago
The rubber gasket is probably just stuck,try a rubber mallet to loosen it Carl
By paul2748 - 9 Years Ago
Go easy with the rubber mallet though
Thanks Boys Appreciate the help Jim
By oldcarmark - 9 Years Ago
When You get it off run a piece of Wire through the Tube that goes back into the block and be sure its not plugged up or remove the 2 Screws holding it onto the Block and clean it. Its the return Tube for oil. Some of the Filters You buy are too long so the Can won't go back on properly. Check the Length and trim if required.
Thanks Jim
