starts but,wont keep running.
http://forums.y-blocksforever.com/Topic122409.aspx
By sewerman1960 - 9 Years Ago
1956 fairlane  will run with foot on the pedal ,as soon as I release pedal motor will stop.
By miker - 9 Years Ago
Well, that doesn't tell us much. Turn up the idle screw on the carb?
Seriously, how much rpm do you need to keep it running?
By WHIPPER - 9 Years Ago
Had trouble getting decent idle on my 56  turned out to be intake manifold gaskets letting air in.
By Ted - 9 Years Ago
I’m with miker and WHIPPER; need more information.  Carburetor issues and/or a vacuum leak would be at the top of the my list though.  On the carb it could be a number of things with the simple fixes being related to air/fuel adjustments and idle speed.  Vacuum leaks could be from a number of places but start with the vacuum hose going to the windshield wipers and the carb base gaskets.
By 55fairlane272 - 9 Years Ago
I feel like a vacuum leak would cause it to idle higher, unless it's a really huge leak. I'd personally say it's the carburetor. Make sure you get everything set perfectly on it. Also, I would check timing to make sure that's good as well.
By Pete 55Tbird - 9 Years Ago
I have no idea what the guys problem might be.
HOWEVER, last week I bought a new 2 stroke weed whacker and filled it with gas and 40 to 1 oil. It started right up but when I tried to open the throttle past idle it would stall. I tried several time with the same result. Stall. The troubleshoot in the manual said if the gasoline was older that 1 month this could happen. I changed to new gasoline and that cured my problem. I was very surprised. I learned from this. Pete
