WTB-y block 239 carb linkage
http://forums.y-blocksforever.com/Topic121762.aspx
By bluesalomon - 9 Years Ago
I am looking for the carburetor-throttle linkage for a 1954 f100, y block 239. The linkage goes from the accelerator pedal rod to the right side of the carb. The truck has a manual transmission. Also, as an alternative, can I connect to the left side somehow?
By carl - 9 Years Ago
I have linkage from a 55, 272 two barrel which might be the same,i will check my motors manual to see if they are   Carl
Did you ever find out if your linkage will fit my 239? From what I have read, the 272 will fit....
bluesalomon (5/18/2016)
  Sorry for the delay,just forgot to check before.The linkage I have is for a auto trans   Carl
