YBlock/FE Dual Diaphram Fuel Pump
http://forums.y-blocksforever.com/Topic12129.aspx
By paul2748 - 17 Years Ago
Has Model 4206 stamped on it. Glass lower bowl, has HC on bottom of bowl (no-not AC). This may need rebuild. Seems to have good vacuum at the top, can't tell at the bottom as the bowl gasket is shot. Pic available. This probably will not fit a TBird because of lower bowl. Very good outside appearance, I started to clean it for my TBird and found out that it may not fit it. 20.00 ?? plus shipping.
