292 dipstick tube
http://forums.y-blocksforever.com/Topic120727.aspx
By Dukeroche - 9 Years Ago
I'm having an issue with my dipstick tube on my 61 F100. No matter how I fit the tube in it rests against the header pipe and does not line up to where it should bolt to the block. I should add that the previous owner pulled the tube out, so thats why I'm trying to put it back in and I'm not convinced its the right tube. I don't like it up against the header but thats the only way it works. Anyone tried those flexible tubes from Lokar? Cant find one specific to the 292. Just looking for other options.
By Dobie - 9 Years Ago
Can you post a pic? Somebody on here show know if it's the right/wrong tube if they can see it.
you just have tobend hear and ther. re the picture it apears the tube  is not in far enough. i am useingthe rams horn manifold on the right sid and had to bend things,as long as tube is not touching the ex you ar ok, end me your email to ct1940@shaw.ca and will send apicture to you.when the tubes ar removed ,usualey bent.
I did get the tube further down to the lip. Still rubbing on the header. Ill send my email.
