By redhot26t - 9 Years Ago
need advice on a good carb for a 59 312 merc am changing to a four barrel manifold. 600 holly too big? econcmaster 450? Thanks for any help
By PF Arcand - 9 Years Ago
Is the engine essentially stock & which manifold?..
The motor is a stock 59 , it is in my 56 montclair 2 brl. manifold now , am picking up a 312 4 brl manifold this week end.
That would be a stock 4 brl manifold Thanks John
I would say a 450 would be more then enough for a stock motor, 600 would be over kill. I'm only using a 390 on my 292. Out of the box it was too lean and I did have to re-jet it. I'm not sure if Holley jets them for the crappy fuel we have today?
By Ted - 9 Years Ago
As a general rule, always oversize the carb when using vacuum secondaries. The reasoning behind this is that the secondaries will only open the amount that the engine ‘demands’ based on the primary venturi flow signal. That’s assuming the secondary spring or secondary weights depending upon the carb design have not been heavily modified in the wrong direction. I have dynoed several Y’s now with the 400-465 cfm sized carbs and based on the high vacuum numbers at rpm, they are all undersized. I recently worked on an original 1955 182HP 272 with the factory Teapot and even it was wanting a larger carb based on the vacuum numbers at 4600 rpms. I have extremely good results with the 750 cfm sized carbs on the Y engines for all around performance but all these typically have some sort of camshaft upgrade. The Holley List #1848 465cfm carb does make a good replacement driver carb though for many stock Y's. For the larger carbs, the Summit 750 carb has been a good choice for many Y builds and I like it better than the 600 cfm version. With all that being said, here are some links to articles that go into detail on some of the carb choices for the Y engines. Ford Y-Block – Four Barrel Carburetor Testing Using the Iron ECZ-B Intake Ford Y-Block – Stock or Modified? Here Are Two Different Builds Ford Y-Block – Stock Iron Heads Can Still Make a HP to the Cubic Inch
Holley sell refurbs on eBay. As good as new, less cost, but a shorter warranty period. As long as you get it installed immediately to make sure there are not issues out-of-the-box, you won't have any problems. If you get a Holley, get a street avenger. It's a more modern carb with a lot of nice features.
Thanks to all for all the good info, a friend just gave me a 1.08 autolite. With the stock manifold, I think it will work. He had it on a 390 and didn't hack the program, too small. Will give it a try first then, do ;what ever is necessary afterwards. My dampener is splitting on the harmonic pulley assembly. so now on the hunt for a good one.
Thanks for the help. John
By Dobie - 9 Years Ago
Check the Damper Dudes or The Damper Doctor. They will rebuild yours.
Will check with the damper dudes, have found it is Hard to find a new one, Thanks John
This is what I used, only new ones I could find. http://www.ebay.com/itm/Ford-Mercury-292-312-Single-Groove-balancer-1955-56-57-58-59-60-61-62-63-64-/171119313455?fits=Year%3A1957|Make%3AFord|Model%3ACountry+Sedan|Submodel%3ABase&hash=item27d781822f:g:SqgAAOxyVLNS1CiF
charliemccraney (2/5/2016)
Holley sell refurbs on eBay. As good as new, less cost, but a shorter warranty period. As long as you get it installed immediately to make sure there are not issues out-of-the-box, you won't have any problems. If you get a Holley, get a street avenger. It's a more modern carb with a lot of nice features. I have one from holleys ebay store,it is 2years old and works perfect i think it was 550 ,i had to go to smaller jets on primarey.it does not have adjustable floats from out side and new style seals at secondarey fill tube. but never had aney isues,i think i wouldgo for a 650 next time. my ranchero is quite stock with eczg rebuilt heads. Charley is bang on
By gyrogary - 9 Years Ago
Damper from John Mummert $219 http://www.ford-y-block.com/damper-steel.htm Summit Racing 750cfm carb $309.97 http://www.summitracing.com/int/parts/sum-m08750vs or with aircleaner combo $292.90 http://www.summitracing.com/int/parts/sum-csum8750vs/overview/
If the Autolite 1.08 is in good shape it should work fine on a stock engine. However, because of its annular discharge design, its recommened to install a new gas line filter at the same time, as they are apparently sensitive to dirty fuel..
