314 (1/6/2016)
Ted. I have a question. I always wondered what would happen with a rod in backwards. These rods have a squirt hole to oil the cylinder wall. With a rod backwards it wouldnt get oil. What happens to the rings and walls.
Jim is correct in that the connecting rod installed backwards on the journal will have the bearing riding on the journal filet. If the backwards installed connecting rod does manage to rotate on the journal (which it might if only one rod is installed backwards), then the rod bearing will be wearing heavily at its outside edge. As far as the oil squirt hole goes, it will still be spraying upwards but if installed backwards, it will be spraying towards the other connecting rod instead of the cylinder wall. As has also been brought up, many engines do not have a direct provision for providing oil to the cylinder wall but instead simply rely on any residuals coming from the sides of the rods.
