By 30 coupe - 11 Years Ago
Have any of you tried, used, or are using these Air Cleaners on the Holly 4000 tea-pot 4bbl carbs. on your y-blocks? I am interested in using them on my 312 2x4 build. I have an Edelbrock 257 intake and a pair of 56 bird carbs, and a pair of 56 Lincoln carbs. I have not made a decision as to which set of carbs to use. I will probably experiment with both. anyway I am looking for some feed back on the air cleaners, as how they fit, are they to restrictive? etc. any help or information would be appreciated. I like the "D" shape of these air cleaners. any air cleaners I use will have to be able to clear the radiator support rods on my hoodless and fenderless chopped and channeled coupe. Thanks for any help anyone can provide.-------Jim http://www.spotlitekustomaccessories.com/store/p7/V8_Dual_Quad_Air_Cleaner.html
By Ted - 11 Years Ago
It’s hard to tell from the picture within the link of any dimensions on the air cleaners. Here’s a picture of a pair of older model dual quad air cleaners that looks similar to the Spotlite air cleaners and these are on a ECG-D dual quad manifold. Here are the carb center to center spacings for the various Y dual quad intakes. Edelbrock FM255 – 8 ¾” Edelbrock 257 – 7 1/8” Edmunds DM-427 – 8 9/16” Mercury ECZ-9424-C – 8 ¾” 1956 Ford EDB-9425-C – 7 5/16” 1957 Ford ECG-9424-D – 7 5/16” Fenton DM-427 – 8 9/16”
By NoShortcuts - 11 Years Ago
Ted: Not my question, but greatly appreciate the carb air cleaner info. THANKS once again to you and other Forum participants for all the information that is so generously shared here.
Regards,
Ted, Thank you so much for the information it is very much appreciated. those measurements will be very helpful. Jim Hackenberger, Palmer Alaska.
By scicala - 11 Years Ago
Jim, based on Ted Eaton's info, if you are using the Edelbrock 257 manifold, the max dia. for a round air cleaner would be about 7". This one on EBAY should work if you double stack the paper filters or put in a spacer.
Sal http://www.ebay.com/itm/6-3-8-Inch-Chrome-Air-Cleaner-4-Barrel-Carb-5-1-8-Inch-Neck-/261871103085
By Larry D - 11 Years Ago
I'm using 9424-D '57 intake with two 500 Edelbrock carbs. No name air cleaners are 6.5-inches in diameter and 2-inches high. They seem to fit well and i've seen them on epay several times. With a higher filter I think they would work on the Holley 4000.
That's what I just mentioned about the ones on EBAY in the post above youre's,
Sal
The Spotlite dual quad air cleaners listed for the Teapots when butted together have air cleaner hole centers that are 7 1/8” apart. Based on that, they will fit any of the ‘old school’ cast dual quad intakes out there including the Edelbrock #257.
By 30 coupe - 10 Years Ago
Thank You Sal, Larry, and Ted. I haven't checked in here for a while, Thanks for the info. now I just have to decide on which "look" I want.-----Jim
By yalincoln - 10 Years Ago
here's another!
By NoShortcuts - 10 Years Ago
yalincoln. Hmmm... Help me understand what I'm looking at. I LIKE the height of the air filter element. Is it oval in shape? Is the filter base Masonite? What are the dimensions of the air filter element? Is there a manufacturer's number? Is the top housing a commercial unit? If so, who is the manufacturer?
THANKS for any info. on what you have pictured. Appreciated!
yalincoln, thank you for your picture of another option, -----Jim
the filter is a K&N, I don't remember the # it's my friends. the top is a old cal custom but we've seen a few new ones at the ford swap meets. I have one on my 2x4 setup with 2 2in tall napa gold 6013 filters, 14.645" x 7.944" oval. the base is cardboard but I'm making one out of 1/4" aluminum plate. I've got a top and bottom made out of 1/4" plastic but not a good idea if you have a fire! i'll get a couple of pics.
hi! I just checked the K&N site! they have the custom 66 series, 15" X 8 1/4" x 3" 0r 15" x 8 1/4" X 5". they are for single carb but you could adapt one with a homemade base!
THANKS for the shared info.! Much appreciated!
Yes, Thanks to everyone for the shared information.------Jim
