Newbie needs help - A/C bracket question
http://forums.y-blocksforever.com/Topic118791.aspx
By TNDoug - 10 Years Ago
Putting an A/C under dash unit in a '56 TBird with a 312.  Does anyone make a bracket for the compressor?  The car has already been converted to an alternator with a nice bracket.  Vintage Air used to sell a bracket but I can't find it in the catalog.  Must be discontinued. Car has a double groove crank pulley-one groove for water pump & alternator, the other for power steering.  Any help would be great. I tried to search the subject but can't figure out how to do a search on this forum. Thanks.
By Barry L - 10 Years Ago
Click on the explore  "button"  at the top, and a drop down menu should pop up, scroll down to find  search. What make of compressor are you going to use? Barry L
By miker - 10 Years Ago
Might try classic auto air. I used their bracket, for one of their kits in my (12v) 55. Used the stock gen bracket with an adaptor for the alternator. Drives the alt and compressor off the same belt. I wasn't happy with that, but slipping has not been a problem. Don't know what they might part out.
http://www.classicautoair.com
Using a SD Sanden 508 compressor with a two groove pulley.  Thinking about making a bracket if I can't find one.
I've sent a request for information on the bracket.  It's not listed separately in their catalog.
By Bob Gardner - 10 Years Ago
Vintage Air lists part number 131109 for the T-bird Y-block bracket.  Only it is for the 507 compressor.  I used there 131111 on my Y-block for my truck.  It mounts the compressor below the alternator and needs a 3-groove crank pulley.  All of this info is on page 70 of their catalog.
By Rono - 10 Years Ago
Bob,
You need a 3 groove crank pulley even without power steering?
Rono
By MoonShadow - 10 Years Ago
There is an outfit in Texas that makes a cast combination alternator/AC bracket. Don't remember the name right now. Someone here should know.
Rono maybe...the way it is set up there is one betlt for the alternator, the second runs the water pumpand air conditioner, the last is for the power steering.  Vintage does have a Y-block bracket for cars that is just what you are asking for. It is part number 15114-VFB.  FYI the Vintage brackets are set up for GM alternators and not Ford.  Ask me how I know. Crazy
Thanks Bob. I am using a GM 1 wire in my 56 Customline and just bought another for the wife's Ranch Wagon. So this Vintage (Air) bracket is a combination bracket for the compressor and alternator? If so, that's GREAT!
Rono
That's was it says in the Vintage catalog (page 70).
Just checked out the Vintage Air catalog and as you said they offer a Y Block alt/AC bracket and aluminum double groove pulley that is required with their systems. They don't include any prices in their catalog, but I'm not there yet anyway. Thanks for the tip Bob!
Rono
