Early Bronco rear drum brakes.
http://forums.y-blocksforever.com/Topic118558.aspx
By MoonShadow - 11 Years Ago
I'm looking for complete rear drum brake setups for an early (66-77) Ford Bronco rear end. 5X5.5" bolt pattern. My rear came without brake assemblies. It's the early rear with 2 dimples.
Chuck Cline's photo.
By paul2748 - 11 Years Ago
Not sure, but look at comparable F100/150's.  If you get the whole shebantg of the bigger truck (including backing plates) they should fit the bronco housing.   You may still be able to find some of these years'  trucks in scrap yards.
By Joe 5bird7 - 11 Years Ago
Suggest you look at the site  ClassicBroncos.com.  You can use most of it's features without even joining if you want.  It includes tons of info on the old broncos, and includes sections for parts for sale, and even a free parts section that often has surprising stuff on it.  If you're into broncos at all, it's a great place for info.  I have a 70 bronco and check that site often.
Thanks for the responses. I will be checking the local wrecking yards. Will also check for other Fords using the same setup. Chuck
CHuck, I just picked up about 30 60's and 70's ford trucks from a junkyard that lost his liscense and town made him clean up, they are down the road from me, sure there is something there that will work!
Sounds like a plan. I'll ID the rear end and get back to you. It is 5 x 5.5"  and I think big bearing old style. Where the ??? are you going to put 30 trucks?
