By Rowen - 11 Years Ago
Looking to find out casting #s for 54-62 y block passenger car bellhousing. Thanks, Rowen
I would be very thankful if one of you folks with a manual trans from 54-62 would let me know what #s may be on your bell housing. I'm going to my local (Williams, Ca) wrecking yard to look for one to convert my 55CV to a stick. I will be looking for a complete pedal assembly as well. None of his cars still have the engines still in them. They are all in a shed and I have to go through them to find what I need. Any help PLEASE. Thanks, Rowen
By carl - 11 Years Ago
Rowen I will check tomorrow for you on the bellhousing Carl
Thanks Carl. GREATLY appreciated! Rowen
By Barry L - 11 Years Ago
  the 6394 is Ford's generic # for bellhousings, here's two... CAG and CAE and a pic of what you're looking for. Hope this helps, Barry L
By 62bigwindow - 11 Years Ago
Are all the car 3 speed bellhousings interchangeable?
By lowrider - 11 Years Ago
Way back in 68' as an 18yr old I converted my 56 CV to a manual shift. I believe all I did was find a 55 or 56 Ford with a manual shift and removed all the parts I needed. Being 18 "I didn't need no stinkin' casting #'s". Worked out good. It was the best working manual shift cars I've ever owned. Wish the 57 I have worked as good as that one did.
Rowen (11/6/2015)
Looking to find out casting #s for 54-62 y block passenger car bellhousing. Thanks, Rowen Rowen the bellhousing number is AE 6394 A ,this was removed from a 56 Ford wagon,the 60s are the same other than extra ribbing on the outer shell ,probably to make them stronger, Carl
Barry L, and Carl, THANKS GUYS!! That is what I needed! I'm going to be going through a PILE of stuff to find what I need and this info will help GREATLY!! Thanks again, Rowen
