312 camshaft thrust spacer
http://forums.y-blocksforever.com/Topic118273.aspx
By Eether54 - 10 Years Ago
Hello guys, I'm putting a 1962 312 back together that another guy started. I'm to the point of putting the timing gears in but am missing the cam shaft thrust spacer. John mummert doesn't have any and didn't think he could get any more. I'm at a standstill on this project until I can source one or have one made. I would be most grateful to anyone that could help me track one down. Thanks!
By Ted - 10 Years Ago
Eether.  If you’ll measure the camshaft thrust plate and give me that measurement, I can send you the appropriate cam thrust washer.  Doing it this way will insure that you have the correct camshaft end play.  You can find my contact information at  www.eatonbalancing.com .  Ted
By 57RancheroJim - 10 Years Ago
I think he said his thrust washer is what is missing?
By vetteman - 9 Years Ago
Can anyone tell me how or show me a diagram of the order of the timing gear and cam spacer and fuel pump eccentric and washers on a 57 T-Bird 312 Y- Block ?
Wayne
By Ted - 9 Years Ago
See if these pictures of the cam hardware from the Ford Parts Manuals helps.  Just remember that the cam thrust washer that goes on first at the camshaft must go on with the bevel facing the rear.http://forums.y-blocksforever.com/uploads/images/8c194bb6-ddb4-45b6-b7c4-3694.jpg
http://forums.y-blocksforever.com/uploads/images/997218a9-d366-4492-b4bb-823a.jpg
