wanted-3rd member or-
http://forums.y-blocksforever.com/Topic118170.aspx
By steinauge - 10 Years Ago
 I need a complete rear end,third member or ring and pinion set for a 49-55 passenger car. I broke a ring gear 3 days ago.Can anyone help me?Thanks.
By carl - 10 Years Ago
where are you located and what ratio do you want. Carl
By Buzz - 10 Years Ago
I have a 3.90 "pumpkin"  I bought on ebay a while back and never used, it's supposed to be out of a good
working rearend - I'm in Los Angelas
Carl and Buzz I am in Florida,32168 zip.Carl,given my druthers I would like around a 3.10 but I will take what I can get. please let me know.thank you.
By Lou - 10 Years Ago
The best you're going to do for a stock rear end is 3.22 (1956 auto) or 3,31 (1951 thru 1955 auto) If you use the 56 rear you have to use the 56 axles or change the spider gears to 49/55 gears.
Thanks Lou,I would happily buy anything I can get in the 3s.Buzz,PM sent.
The nearest ratio I have is a 1955  3.55, shipping would be from Ohio so probably fairly high
steinauge, got ur PM and sent you a response.
