By jimcar-9 - 10 Years Ago
Hi
I am planing on rebuilding my 272 eventually, (Not right now, just collecting parts) It pretty much goes like this
272 0.040 over (278ci) -B intake -G heads +10 cc dome pistons Mummert ram horns Mummert 270 cam (max 5800)
If I make some number crunching it says that the carb should be at 378 cfm at 83% volumetric efficency and 466 cfm at 100% but I guess this setup would never come near 100%
This is going to be stock(ish) looking/handling truck with some grunt under the hood. So I prefere some streethandling caracteristic like low end torque instead of dragstrip ET performance
So I have been hesitating between the Holley vac 2:nd 4160 model 390 cfm or 465 cfm......
Put out a question in a facebook group and got replies everywhere from "390 is perfect" to " 390 is WAY to small" " 465 is the absolutley minimum" "you could use a 650 at least"
I am at the moment leaning towards the 390 (as the numbers tells me), as I have a hard time understanding that the vac secondary would really be much use on a 650 carb when the numbers says the engine setup only needs abput 390 at the top end??
I know the are some gurus on here that might lead me in the correct way.
Thanks in advance
By PF Arcand - 10 Years Ago
First, is the vehicle actually going to be used normally as a truck?
Sure, I will be towing stuff up to 3300 lbs once and a while and the bed will see the city dump more than once.
Not a streetrod of any kind more of a truck. And maybe a redlight race when I feel for it (not very often)
I don't think you're going to be towing 3300lbs with the 270 cam. That cam is getting closer to the street rod / hot rod end of things and your low end will not be as strong. The rpm range for it is 2000-5800. You need a cam that works from idle for towing.
I stand by my recommendation that a 465 is the minimum and a 570 will probably work well for you. Err on being a little bigger than necessary with a vacuum secondary carb.
I am open to suggestions would the 265 cam be more appropriate.
Or is it the stock cam that is need?
Or are there any other cam manufacturer and grind you could recomend?
charliemccraney (10/7/2015)
I don't think you're going to be towing 3300lbs with the 270 cam. That cam is getting closer to the street rod / hot rod end of things and your low end will not be as strong. The rpm range for it is 2000-5800. You need a cam that works from idle for towing. I stand by my recommendation that a 465 is the minimum and a 570 will probably work well for you. Err on being a little bigger than necessary with a vacuum secondary carb.
The rear axle has a ratio of 4,89. That should effect the towing as well to the positive....
Its also a manual trans, alot more formgivning than an auto when towing
By 57RancheroJim - 10 Years Ago
Are you sure the rear ratio is 4.89 and not 3.89? I have a 3.89 rear with a 3 speed OD, 292 with a Isky E4 cam and use a 390 Holley and have no complaints, runs great in town and on the hiway. I did go to a larger squirter and upped the main jets a little..
By speedpro56 - 10 Years Ago
I think with the rear end ratio the 270 should be fine and I'm with Charlie on the 465 cfms Holley, even the 570 would work. I'm running around a 265 duration in my stock built 292 in my 56 convertible and feel like it needs to be a 270 duration cam at least. We tend to forget with our solid lifter engines we lose a little duration and lift with our lash adjustment which lowers the cam profile some from what I've read.
By chris70 - 10 Years Ago
Hi,my truck has an Isky E4 cam G heads and the 3.89 rear axle and i use a 390 vacuum secondary and 1 inch spacer and it is a pleasure to drive even in traffic with really good low end torque,with manual trasmission you should have no problems with this set up. Smaller carburetors have a better signal at the Venturi by lower rpm than larger,on the othe other end you loose power on higher rpm range.
You might get away with it with a 4.89 gear.
Chris, the E4 is a little smaller than the 270, which may make it stronger on the low end. Do you also tow 3300lbs with it and haul stuff to the dump? There is a big difference between cruising around with no load, versus towing.
My cam is a hair bigger than the 270, with more displacement and the low end is noticeably lacking for towing. This is in conjunction with a 3.70 gear. I have hauled probably about 1000lbs in the bed, an assembled Y, the automatic transmission and an engine hoist. While it did it, I wouldn't want to do it for anything that is even remotely regular. It's absolutely fine if not hauling anything of significant weight. If anything, the cam is a bit small for me and the way I currently use it.
I have a 1957ranchero,.040 over bore,bone stock cam,g heads 3.25 gears,3speed trans,570 holley vac. sec.it works well, good lift frome a stop on a hill, i have instaled ford dura spark ign in the dist with 45gaped plugs.will install a 57 312 regrind cam in the future,to get some more high end grunt..tho my present resto takes most of my time,1948 merc f47 cnadian (f1),power will be 292 y with c heads modified to 190 intake valves,4speed manual,with 4th od.wondering about going to a 3.50 gears. still looking for 9in diff
Of course, my misstake 3,89 and nothing else.....ops
I will check out the isky E4 and look at the spets for that.
Thanks for the feedback guys
Keep em comming
