For Sale: Misc. Stuff, not Y-Block specific, ARP Carb Studs, Spectre alternator bracket, Pertronix Ignitior and Wires, K&N filter, Autolite 2V carbs
http://forums.y-blocksforever.com/Topic116119.aspx
I have a few things I don't really need.  Kinda random stuff.  I can bring these to Columbus or ship.
Feel free to make an offer.  My willingness to budge depends on how much I think I can use the item at some point.  The worst I can do is say no.
I'll add the Autolite carbs in a day or two.
For some reason, the site doesn't like some of my pictures.  If you need to see it, ask.
Definitions:
Never opened means if there was any factory seals, they have not been broken.  Some items are not sealed, so never opened means things like parts bags contained within have not been opened.
Autometer Designer Black Tachometer, part # 1296, black face, white numbers, 0 - 8000rpm, 3 3/8" diameter, domed glass, chrome bezel.  Brand new, opened, never used.  $150.00.  I have all of the original packaging, instructions, hardware, etc.
Fits in the side of '61-'66 F-series gauge panels nicely.  Panel not included.
ARP 200-2408 carb studs.  3.200" length, black oxide, 6 point nuts.  2 brand new, never opened, 1 brand new opened.  I intended to use these for rocker stands but it was a pita to get the rockers on with only four so I won't be doing that.  The opened set was threaded by hand through rocker stands, but never used.  $13.00ea for the unopened sets, $10.00 for the opened set.
Spectre 42263 alternator bracket, for scruby.  Brand new, opened, never used.  $5.00
Pertronix 706101 stock look plug wire set 6 cyl, fit many makes.  Brand new, never opened.  $20.00.
Pertronix Ignitor 1261, fits many Ford 6 cyl.  Brand new, never opened.  $40.00.
K&N Air filter E-1210, 11" diameter, 2 3/16" tall, used.  Not sure of exact mileage, but shouldn't be much more than 10000, if it is that high.  $15.00
Galvanized cable, 50', 3/16" diameter, 840lb rating.  Brand new.  $5.00
Everything above still available.
Autolite / Motorcraft carburetors.  I doubt any of them will work as is.  Definitely need rebuild, good for parts  $15ea.
Top left to right
KBA 1BA, 1.02    C7DF R, 1.14
Bottom left to right
DBA 1BA, 1.02     No tag, 1.14
I thought I had a pretty decent one for a Y-block but couldn't find it.  I'll check some other places tomorrow.  Can't find it.  Maybe I imagined it.
Last chance for Columbus delivery.
still available
I still have this stuff.
btt
By MoonShadow - 8 Years Ago
Bring the cable along Charlie I'll take that at least.
Will do.
By Y block Billy - 8 Years Ago
Who do you plan on towing down the track with that cable Chuck?
You Bill! I need a new cable for my winch in the trailer.
