Oil and breaking in an engine
http://forums.y-blocksforever.com/Topic115094.aspx
By jdwilker - 11 Years Ago
I'm getting closer to starting up my rebuilt 292 and have been reading up on the proper oil to use (maybe reading too much). I came across this article which goes into it in detail so great my head is spinning.  I know this is a subject that has been talked to death, but what kind of oil do you use and what do you think of the article's recomendations?
https://540ratblog.wordpress.com/2013/06/20/motor-oil-wear-test-ranking/
By Bob Gardner - 11 Years Ago
Use a good break in oil like Gibbs or Brad Penn.  These oils are "dinosaur based" with zinc and other additives to protect flat lifters and cam.  Stay away from synthetic oils until the rings have had a chance to properly seat (~5000 miles) and remember that older engine seals were not designed for this type of oil and may leak.
I guess 2 things that I took away from this article is: 1 - High levels of zinc do not necessarily equate to higher wear prevention, and 2 - The oils with the highest wear prevention properties are synthetic which everybody says you shouldn't run in a Y-block.  What do you folks think?
By 57RancheroJim - 11 Years Ago
jdwilker (6/4/2015)
I've read that blog several times in the past, it's a lot to ingest, and some will believe it and some won't. Everyone will tell you something different about what oils to use so I won't add to the confusion. All I will suggest is spinning the pump to fill the filter and galleries first and bring the RPM up to 2500-3000, the cam depends on splash oil.. I broke my FE solid lifter motor in on Delo 15-40, running for 4 years with no problem. I used Shell Rotella T in my 292 and after 5,000 miles it's fine.
Try this sitehttp://speedtalk.com/forum/viewtopic.php?f=&t=32279  be sure to read the whole artical.this paper takes all the old wives tales out of oil,also will save you some dollers. it proves diesel engine oils are a poor replacement for even the cheapest gas engine oils.
Tried that link, but it's not there.  Do you have it somewhere else?
jdwilker (6/5/2015)
the site wont copey the long adress(  http://speedtalk.com/forum/viewtopic.php?f=1&t=32279)
send me your email and i will email the whole adress,cant understand why the site changes the adress,as if 1 uses the whole adress ther ar several sites canadian and us.cliff ct1940@shaw.ca
Show me an auto oil that has a better additive package then these, especially the Delo 400
The Petroleum Quality Institute of America
ther is a big list,if you choose to learn go to the site,dello 400 is ok but sure not the best  dello 400 has a load max of69367psi,rotellat is67804.
mobil 1 is82263, psi    890pm zinkmoley819ppm phos819ppm
20/50 castro lgtx 96514psi zink610ppm phos754ppm moley94 ppm thes ar some of the test results.
oil categories for gas  arover90000psi, out standing
75000-90000 good protection
60000-70000 modist
60000unexceptable forgasengines ,esp flat tapet. just afew frome the toatle test results
It wasn't very long ago that people and some cam manufactures were blaming cam and lifter failure on a lack of Zinc in newer oils. That was one of the reasons people started using the diesel oils, as did I. Right or wrong I can't say but I can say I haven't had any issues using it.
By Ted - 11 Years Ago
For flat tappet camshaft break-in, it’s important to use a oil that has high shear properties.  If the oil is ‘too slick’, then the lifter will simply slip on the camshaft lobe and not rotate.  It’s because of the reduced shear properties in synthetic oil that it is not recommended for a flat tappet camshaft break in.  Another general rule for flat tappet camshaft break in is to not use an oil with less than 30 in its viscosity rating (ie: 30W, 5W-30, 10W-30, etc) simply due to oils with less than 30 also having reduced shear.  While some of the diesel oils available have a zinc/phosphorus content suitable for flat tappet camshafts, the detergent level is considerably higher thus promoting increased wear on the engine bearings in a gasoline application.
By CK - 11 Years Ago
So synthetic oil is good to use in a flat tappet cam engine once run in?
Or would it be better to just stay with a mineral oil?
I used a run in oil 10/40 for about 400 miles and now running a full synthetic pao/ester 15/50 oil.
Penrite the oil manufacturer I'm using list 20/60 semi synthetic for the y block.
I guess as teds "eaton balancing" blog suggests regular oil changes At 3000miles is as important.
By steinauge - 11 Years Ago
Well,I have used 20-50 Castrol GTX in all my hot rod engines flat or roller tappet for a very long time now both as break in oil and for regular use.Before multi grade oils were commonly accepted by rednecks like me I used Kendall 30 wt.These days I use 2  ounces of redline zinc additive at each oil change.I change oil and filter in my Y block at 2000 mile intervals .I realize that is more than needed,it just makes me feel better.Initial fireup on a fresh engine I pre oil the engine in the usual manner ,fire it up and run it at  varying rpm between1800-2200 for about 20-30 minutes .I have never had a problem doing it this way yet.I suspect that proper assembely lube and pre oiling are the really critical items.I use a lot of cam assembly lube on the cam lobes and lifter faces.
the lab tests i have quoted ALS Tribology, sparks nevada usa indicate load carrying capacity which efect camshafts and the other rotating components,as well as temp. when thermal breakdown starts. for example shell rotela t 15/40 hsa72022psi load capacity,thermal bd 250d 2886pm detergent
older rotellat 71214psithermal bdown 250d det 2715 pm.. so this is contrarey to bearing wear would occur do to detergent.
now look at oils that ar for s(spark ignited engines) des.  mother craft 5/50 103517psi
   5/30 sheveron supreme conventional 100011psi zink 1018ppm  phos ppm 728 molley161ppm
5/20 castrol gtx covemt 96514psi zink610 ppmphos754ppm  molley94ppm.  the tester goes on to scythe aditive packages ar different load noes are the key,as aditives ar used up change  intervals com into play.the paper goes on to say diesel engine oils ar ok but are no wher nears coded motor oils for gas enginesespecialley whe flat tappet cames ar in play. those who has good results with oils like rotela t wher probebley mild  n performannce and worked ok,but with less insurance frome dry starts, stickey valves ,poor oil supply to rockers etc. when i was working the co sold shell products, we wher cautioned not to use rotelat as it could harm f tapet cams. the need for more detergent was due to exhaust recerculatiom to meet present env. laws. created moer slidge etc..i found this paper very informative , but lots of reading. finally lecters on ignoring gosip and get facts from magor oil cos.
I have found reading all the test numbers interesting but I wonder what these numbers might have been on the old oils we ran in the 60-70's as a comparison. I had built and ran numerous Yblocks and FE's during that period and always used 30W Vavoline. People used all different brands during those years and I don't remember any cam and lifter failures, I never had any.
the tests are recent(3 t0 4 years) the tests on new and old rotela t diesel lube is a indicater as well as results for joe gibs race oil,how long has he bine in nascar would be a guage.
0
