By MoonShadow - 10 Years Ago
I am looking for the chrome passenger side sun visor mount off of a 56 Montclair(?). The one with the chrome interior trim. I have all the rest.
By carl - 10 Years Ago
MoonShadow (4/27/2015)
I am looking for the chrome passenger side sun visor mount off of a 56 Montclair(?). The one with the chrome interior trim. I have all the rest. Chuck can you send me a picture of the bracket that you have Carl
I am looking for the chrome passenger side sun visor mount off of a 56 Montclair(?). The one with the chrome interior trim. I have all the rest. Chuck I have a couple chrome sv brackets which I think is 56 Montclair part numbers are BV - 6404123-A @ BV-6404122-A,I am not the best at marking parts so these may or may not be what you need Carl
I'll check the numbers tomorrow. Thanks for the response. Chuck
Carl, Tried to message you but it says your box is full. I didn't get to check out the visor bracket I have. I'll try to get a picture tomorrow. Chuck
Finally got some pictures and its a good thing. The part number says its for the right side. Chuck
Chuck That does not look like the bracket I have Carl
By speedpro56 - 10 Years Ago
Chucks look like it's off a 56 4dr. phaton merc. A 2dr is different.
Thanks, I hope you're wrong. They aren't cheap. Seems the crown guys go after them. I have every thing from a Merc except those 2 pieces to complete a stainless interior trim on the vicky. Chuck
Chuck, the 4dr Phaton HT I sold a few years ago had the visor brackets you are showing. The Crowns look similar to convertibles and the Victoria 2dr Hts are elonglated and taper off if memory serves me correctly. If chroming the inside I would use the ones for the 1955 Crown upper center piece and have your visor brackets chromed. Just a thought.
Are these the style I need? I have the over under and sides from the Merc in stainless. Chuck
That's the style used on Crowns and convertibles but do you have the pieces that extend over the door like in the crowns? These pieces ended when they joined the inside crown upper chrome strip crossing the top. I may have a set for a Victoria but they were painted from the factory and are as I described earlier.
I have all of the pieces, at least I think so, the top and side pieces for the rear window, the two over the windows pieces, the top and bottom of the windshield and the sides. The cars not here so I can't test fit. I thought all I needed were the visor brackets. I also found these new at Dearborn Classics:
If you have all the side pieces and they fit, you should be ready to go.
Is the small one pictured the ones I need? Chuck
Chuck, If you are putting them on your 56 Victoria then what pictures you are showing are not the ones that came on the 56 Victorias. The 56 vickys are a one only year.
I have the ones for a 56 Victoria and are in good shape. They came painted from the factory. Ford did not chrome them, that you would have to have done yourself.
I should have the Vicky home again later this week. I'll be able to see what exactly I need. Carl thinks he has the right ones and I'll try to pin them down. I have all the other Montclair interior trim. Chuck
