Odds and ends for sale
http://forums.y-blocksforever.com/Topic112158.aspx
By Doug T - 10 Years Ago
As of Feb 19th there has not been much action on these items although a fair number of people have looked at the stuff. So if you want to make a reasonable offer please feel free to contact me by e mail or personal message.
Doug T
Here are some bits and pieces that I have laying around.  Please contact me by personal message or leave a question or e mail address on this thread so that we can arrange payment and shipment.  I usually ship USPS as reasonably quick and economical but I will do what you want.
Exhaust manifold diverter valve:  $40:00
This used diverter valve turns freely from closed to open with its own bimetalic spring as shown in the pictures (which was done with an electric heat gun).  It is correct for all 1957 T Birds or Ford V8s. It needs the small anti rattle spring to be complete.   Ships from Louisville Ky buyer selects method
http://forums.y-blocksforever.com/uploads/images/41dcda9c-540d-44bd-a01e-b06d.jpg
Generator mounting hardware: $25.00
I see these on sale on EBay often I don't know if they sell. This is the complete 3 piece set of stock hardware to properly mount a stock generator to a 1957 Ford V8. It includes all original mounting hardware,  the nuts are oversized from normal.  It is believed to also be correct for any '54 to '62 Ford Y Block V8 car.  It will not work for '55 to '57 T Birds and some trucks.  Ships from Louisville Ky buyer selects method
http://forums.y-blocksforever.com/uploads/images/4c94a576-dd07-451a-b44c-fdc2.jpg
3 1954 Head gaskets $25.00
These are steel shim head gaskets that will fit 1954 239CID engines only They were mixed in with some regular gaskets and are NOS as far as I can determine. the used one on the right is for comparison.  Ships from Louisville Ky buyer selects method.
http://forums.y-blocksforever.com/uploads/images/d294dc3d-9460-45be-a4a3-e6d3.jpg
T bird and Truck Ford Y Block front motor mount   $15.00
New rubber for the front motor mount of '55 to '57 Thunderbirds and some Ford trucks.  Will not work for passenger cars. This is new from a reputable vendor and is left over from my project.  Ships from Louisville Ky buyer selects method
http://forums.y-blocksforever.com/uploads/images/4e59353b-dc41-417c-a46b-dce2.jpg
Ford Y Block Vacuum advance  $ 15.00
This is the late model vacuum advance that goes in a stock Ford distributor with the pivot type point mounting plate,  NOT THE BALL BEARING TYPE.  New never installed, no box. Ships from Louisville Ky buyer to pay and select method.
http://forums.y-blocksforever.com/uploads/images/7a5e31c8-4ef2-465f-8429-2111.jpg
 Rebop original water pump spacer  $50.00
This spacer is required to use an Iron or aluminum water pump on a '55 to '57 Thunderbird. It is currently not available in aluminum.  This one has been used on my T Bird but is undamaged in any way. I have gone back to the iron parts for other reasons.  Ships from Louisville Ky buyer to pay and select method
http://forums.y-blocksforever.com/uploads/images/c20dc734-89aa-4add-8eb5-69d6.jpg
