Photo test post for Charlie
http://forums.y-blocksforever.com/Topic112100.aspx
By snowcone - 10 Years Ago
Photobucket test as per your request Charlie
As you can see, the image is not appearing but the 53% text is linking to the image
When you first open the post the image quickly flashed on the screen and the changes to the 53% text
This is how I am seeing it anyway, but possibly it is appearing OK to other users
PS - I just posted the same image on another site and it worked perfect
By pintoplumber - 10 Years Ago
Snowcone, when I post pictures from photobucket, there are 4 lines of text. I have to remove the top 2 lines leaving only IMG. At the end of the text, I remove the last 6 characters including the brackets.
I'm not sure what is happening.  My own picture works.  To get yours to work, I deleted the URL related info and left the IMG related info.  Click edit on your post to see what I did.
Even if I type out the whole thing, the result is the same.  If I copy your link info into my working info, the result is the same.  If I view your picture on photobucket and copy the link and picture info from there, to ensure no errors, same result.  I don't understand that.
By ian57tbird - 10 Years Ago
Hi Gary.
Your picture does not appear on this page but if I click on the link it opens another window so that appears in photo bucket OK.
Have you tried using the insert button below. If you select insert then move the cursor across to the second shape it should say insert image and if you click on that it then gives you a browse option for you to find the image on your computer.
To me that is much easier than using photo bucket. About a year ago there were problems with the insert image with the software upgrades but that all seems to be ironed out now.
.http://forums.y-blocksforever.com/uploads/images/3a52804c-38f9-458b-921a-21c9.jpg
