Interceptor marine parts
http://forums.y-blocksforever.com/Topic110913.aspx
By dbird - 11 Years Ago
I just bought an Interceptor for the long block, all the marine parts from the flywheel forward are available.  I'm not sure of the year, but the block is a B9. No bellhousing.  The exhaust manifolds sit above the spark plugs.  Most parts seem in reasonable condition, corrosion on one of the water outlets, water pump makes noise,and a couple of minor dings in the valve covers, but that's about it.  Located in Modesto, CA, easy delivery to the east bay or Sacramento. Would prefer to sell as a lot $600 or some reasonable offer. Willing to sell individual items if I can't sell tie lot in a reasonable time. Let me know if you need pictures of anything or if you need any additional info.
Thanks,
Don
Ok, things aren't moving, so offers would be appreciated.  Polish the intake out for an awesome low profile look,  Large capacity aluminum oil pan with windage tray and aluminum front cover with no water pump is waiting for your dragster, chrome valve covers probably should go with the intake for the oil fill,  The exhaust, well you pretty much have to use those on a boat.  Shipping would be pretty much what it would cost me, FedEx is only a couple of miles away.
By Cliff - 11 Years Ago
Hi, how much for the pan and timing cover.
Cliff
How about $125 plus shipping for the cover, oil pan with pickup tube, front pulley with spacer, and timing pointer.  I don't know how the front pulley would work on the street as it doesn't have a dampener section.  The pan might need some modification for street use.
Don
By Larry Short - 11 Years Ago
Don,
If Cliff doesn't want them I'll take them. Can use on my Y-Block dragster.
Larry Short
724-312-4285
Hi, is the pan tapered or flat?
Cliff
PS My zip 90807 (california) any idea on the cost of shipping
By dbird - 10 Years Ago
The pan is tapered, about 1 inch shorter at the rear, My angle measurement showed only about 5 degrees, but it looks like more.  Shipping looks to be in the $20-25 range to your zip, Fedex ground
By Cliff - 10 Years Ago
I'll take them, send me your address and I'll send the money.
Liqu@aol.com
Front cover and pan are sold.
Thanks Cliff
Don
Nice Parts
Thanks Cliff
By magiemae - 10 Years Ago
Do you have the Flame arrestors.If so price
I still have the flame arrestors, but until the manifold sells I want to keep them together.  If enough time goes by or for some reason they become available, I'll be in touch.
Don
All I have left is the exhaust, water pump, flywheel and mounts.  The exhaust is pretty nice, the water pump I would use as a rebuildable core, the flywheel and mounts are in good shape. Water pump, $25 obo plus the ride, exhaust $250 plus the ride and they're heavy.  The flywheel and mounts, make an offer but shipping would probably be more than they're worth.
Don
By talljhon - 10 Years Ago
Do you still have the parts and if so, what type of oil pump is it?
