By Glen Henderson - 11 Years Ago
It is time for me to move some of this stuff, I have too much to list and certainly too much to post pictures of. If you need something give me a call 334-799-6577 or you can email me rebelrousergarage@mindspring.com, the PM feature on this site does not work for me.
G heads- several sets 113 heads C heads many late small valve heads ECZ-B intakes ECZ-A intakes two barrel intakes complete 292's, blocks Piles of sheet metal parts, pans, valve covers,ect Drawers of small parts Some 57 ford parts 61 thru 66 f100 parts I will not ship the big stuff but if it will go in a flat rate box, I will mail it.
By Genuinerod - 11 Years Ago
Looking for a flywheel cover. This would go on my manual transmission T-Bird. How much to northern California? Thanks, RHill
I'll have too look and see if I have a manual cover.
Here are a few pictures, you will see why I can't list each item.
By PF Arcand - 11 Years Ago
Noticed crankshafts in the background.. for sale?
Yes Paul, all 292's no 312's most will need turning, I have a couple of .010/.010's that will polish out.
By 64f100 - 11 Years Ago
I'm interested in a set of the 113 or G heads and the b intake. I sent you an email last night. Let me know if you didn't get it.
Thanks.
Nick
By ajrobbins62 - 11 Years Ago
looking for nice rocker arm set, what are they 1.53,aluminum water pump,6,7,8, quart oil pan(64 F100) or aluminum oil pan, any thing cool trying to put something interesting together for my son
By 56_Fairlane - 11 Years Ago
Do you have a 57 non-T Bird air cleaner?
By FORD DEARBORN - 11 Years Ago
Greetings Glen: I need a usable set of 312 connecting rods. I also sent an e-mail with the same request. Thanks, JEFF.........
OK guys give me a little time and I will get back to all of ya'll, I work at the NAPA store Mon and Thues so it will be Wed before I can start digging through this stuff. I will try to send each of you a PM, but for some reason I can;t receive PM's. If I send you a reply, you may want to call or email me. Thanks, Glen
By randyh - 11 Years Ago
Glen, Sent you a PM.
Glen, I don't think I will need an air cleaner after all. I thought the one I have was from a 58 or 59 but it is actually from a 57.
Let me see if I can answer some questions in one post, I do appreciate all the response. All the B intakes are sold, I do have a couple of A's $75 ea. I don't have any 312 rods that I would use. I have 2 sets of G heads left, but I would suggest having them checked for cracks 1 SET SOLD I have a real nice 57 breather, and a nice 56 breather I have a couple standard flywheel covers from pickups, but I don;t no if they will fit a Tbird for the gentleman from Cali. I have some loose 1.53 ratio rockers I have one set of 1.53 rockers with new shafts with Ted Eaton's oiling mods $175 shipped I don't have a oil bath air cleaner that will fit a four barrel I have valve covers and valley pans, road draft tubes ect.
I will try to get pictures out this weekend to those of you that I promised pictures too
Again I can not receive PM's from this site, so email me at rebelrousergarage.com, I have moved a lot of parts, but have a lot more. If I have not replied to your request send me another email. Thanks Glen.
By Dave Doll - 11 Years Ago
Im looking for a ecz-b intake and a set of 312 heads for my 292 phone 406-698-0489 thanks Dave
By Lawrence Petty - 10 Years Ago
For a 292 am looking for the can shaft oil drip trough and for the crank shaft needing the spacer and oil slinger. Got long block and it seems to be missing these parts. Does the crank need both a spacer and slinger on the 292?
By Glen Henderson - 10 Years Ago
I am sure that I have another slinger, as Ted said in the other post, I don't know what spacer you are talking about. The camshaft drip thing was deleted on later Y blocks and most don't use them. I'll dig around and see if I have the slinger.
By Jim Rowe - 10 Years Ago
Glen,
I need a passenger car oil pan with complete pickup tube from bottom of pan to oil pump.
I live in eastern Nebraska. Any idea on the freight cost? JIm 402-681-1770 cell phone mjrowe@cox.net
