y block fuel injection Hilborn
http://forums.y-blocksforever.com/Topic108772.aspx
By hemiguytoU - 12 Years Ago
looking for a ditributor drive pump for my Fuel injection unit
By Larry Short - 12 Years Ago
http://forums.y-blocksforever.com/uploads/images/78fac6b3-1407-4bcc-8cf0-4aef.jpgI
I think this is what your looking for ? Sorry this one is not for sale , It's going on my 50's Y-Block powered front engine Dragster. Be careful if you find one. I had to send mind back to Hilborn for a complete rebuild. They don't have many parts left for these. I'm using a Vertex Mag on top and found the bottom mag adapter on e-bay. I would keep checking e-bay, never know what you'll find on there. Also the new shaft from Hilborn use a hex drive for the Dis/Mag not the old slot Dodge type. Hope this helps a little. Larry Short
http://forums.y-blocksforever.com/uploads/images/fdb17f17-dc1b-4b37-806b-3daf.jpg
Hears a better look at the inside where the Mag bolts on. No longer do the use the slot drive. Larry
http://forums.y-blocksforever.com/uploads/images/76fd1b09-5dc1-475b-bab8-390b.jpg
This is my unit I got a few years ago at the Columbus fall swap meet. Larry
Hey Hemiguy , Just saw a Hilborn distributor drive pump with mag on top on e-bay. It's not for a y-block but might be able to be made to fit. Tops and pump are all the same could possibly machine bottom to fit. Hilborn sells new shafts for y-blocks. Look under Hilborn Injection
Larry Short
