flywheel
http://forums.y-blocksforever.com/Topic107081.aspx
By yalincoln - 11 Years Ago
I need a flywheel for a merc. 312, cruise-o-matic!
By Glen Henderson - 11 Years Ago
Is it different than a ford, if not I have one from a 57 and I can bring it to Columbus.
I need the lat e flywheel with the ring gear for a 3 spd.  the early ones used a flex plate with the ring gear on the converter, and the 2 spd. ford-o-matic is different. I'm going to use a FMX behind a 312. thanks.
I'd be interested in an aluminum bell housing also, thanks. i'll be at Columbus.
By carl - 11 Years Ago
I have both the aluminum bellhousing and later flex plate with ring gear that I might sell.  Carl _   Circleville Ohio
