Wanted 1959 292 Y Block Fuel Line - Carburetor to Fuel Pump
http://forums.y-blocksforever.com/Topic106297.aspx
By '59Edsel - 12 Years Ago
I am in need of the fuel line for my 1959 292 Y block. The piece that runs from the carburetor (ford 2100) to the fuel pump (vacuum wiper version). It is important that it comes from a 1959 model since the carburetors made from 1960 onward have a different thread pitch for the fuel line. Picture coming soon!
By carl - 12 Years Ago
'59Edsel (7/26/2014)
 I might have the fuel line you need for your 59 edsel,had one if I can locate it   Carl
Thanks for the quick reply! I will patiently await to see if you have it.
Photo: (The yellow line is what I have on my car, as you can see someone had cut it to hack in a fuel filter)
http://oi61.tinypic.com/8z3gcp.jpg
By 56_Fairlane - 12 Years Ago
On my 56, someone put the filter just before the pump where the flexible fuel line would go.
56_Fairlane (7/27/2014)
I have one there too Smile
I checked the gas lines I have and they are for the inlet in the rear carbs ,it don't look to difficult to fabricate your own fuel line,i made a pattern out of a heavy piece of wire then bent to tubing to shape [twice}  Carl
Thanks for looking. I just may have to fabricate if no one has one.
Anyone?
I got one of these. http://www.macsautoparts.com/ford_mercury_late/fuel-pump-to-carburetor-fuel-line-ford-292-and-312-v8-with-2-bbl-or-4-bbl-autolite-carburetor.html
It may be more than what you may want to spend.
Last ditch effort
