By mongo - 17 Years Ago
I will be getting my 1st shipment of these new light wieght blow proof bellhousings for y block to T5 - 5 speeds, in 3 days, will pictures, they come with an engine plate too ! I did not order them , but I can get a different bolt pattern for borg-warner 4 speeds too. call me at 931-739-0152
By JPotter57 - 17 Years Ago
Prices? I would be interested in one for a Toploader.....
The Manufactor has warned me about list price, if I want to make any deals, they don't want to hear about it. If you call me, 931-739-0152 . We can get it to work, Quicktime has stepped up and made a excellent product. Dave Bolton
By Dennis K. - 17 Years Ago
Mongo, What flywheels and starters are compatable with the Quicktime scattershield? Their website calls for a 164 tooth flywheel. Regards, Dennis
I am pretty sure , any of the newer starters will work, when they come in I will bolt 1 up, put a wheel on , try a couple starters, got a mini starter too , spin it over. I have not used an old style starter in a long time, they may not fit, no big loss either.
Davie, A 164T Ford design flywheel is a 300 CID truck or a 302/351/460 one that is neutral balanced. Question is will they bolt to a 292/312 crankshaft? If yes, I would also assume compatibility using the later starter. The old 292/312's were 146T with the early Ford inertia starter. Currently, I have an aluminum Fidenza 146T wheel with the early starter. The early Ford inertia starter may not even package into the Quicktime scattershield, yet alone have the correct center distance between the gears. Regards, Dennis
I have bunch of different flywheels, and starters,including the old type , will try during the week >
Dave, Any updates on flywheel/starter compatibility with Quicktime scattershield? Regards, Dennis
Dear Dennis, I received the shipment , very complete kit ,well made, but issues with clearances for all stock parts. I am currently working with Quicktime to retool the next batch they do. They are coming now with gloss black powdercoating. I order in a different color, your thoughts ?
