Adjusting telescoping steering wheel?
http://forums.y-blocksforever.com/Topic104001.aspx
By Joe-JDC - 11 Years Ago
I have been looking for an old Y-block car, and have not had much luck until yesterday.  I had a '55 T-bird offered at a price I could not refuse, so it is in my garage.  However, it has the steering wheel back a little too far for my tastes and height.  The previous owner, a widow lady, said it was adjustable, but did not know how to show me.  Can any of you point me in the right direction, or give a quick answer?  I thought I would check here before going Google.  Thanks in advance.  Joe-JDC
By miker - 11 Years Ago
There's a knurled piece on the column. Left to loosen, and the wheel should move either in or out. There's not a lot of travel. If it hasn't been moved in years it could be stuck. Don't break the steering wheel, it's worth a fortune. The actual slip joint is inside the column and just out of the steering box, under the hood.
By slumlord444 - 11 Years Ago
I would soak the collar with penetrating oil for a day or two if it will not loosen. Oil filter wrench may be useful also to loosen the collar.
Thanks, that seems simple enough.  Will check it out this PM.  Joe-JDC.
By dbird - 11 Years Ago
Chances are, it's probably all the way in.  If you can't see a gap between the collar and the rest of the column on the wheel side, it's in.  The wheel is close to the seat by modern standards. I took the stops off the seat back so it reclines a little more giving me some room.
Don
Actually it was all the way out/back.  I was able to turn the collar with my hands, and simply pushed the steering wheel in about 3 inches, and it fits me much better.  Thanks for the tips, I will probably be asking more questions all along.  My first car that I actually owned/drove was a '56 Fairlane Victoria 2 door hard top, blue and white with 292.  I rebuilt the top end of the engine in 1962/3, and I dated my future wife in college while driving that Fairlane.  I have been looking for another one ever since.  We bought our first car together in 1966, a red mustang 289, and have had Fords ever since.  Still married to the college sweetheart, 48 years later!  Joe-JDC
